Motherboard with case incompatibility
Solved by KKLawrence,
So, unless you want a complete OC'ed build with custom watercooling, both of these parts are overkill. For almost any budget. Rather aim for the Z690 Aorus Elite (it's just ATX) and a 5000D or 4000D Airflow, these will have similar aesthetics and functions with a way lower price.
If you want to badly keep the components you selected, which I would advise against doing so, then you can just buy them together. If you check out the Manual on the 7000D, you clearly see that an E-ATX Board fits with lots of room, because its a gianormus case.
