Randomly loosing display, PC not crashing? 3060ti
Npiet1
So I keep loosing a display signal. Completely randomly, once it happens it gets faster and faster until. I leave it off or unplug and replug. Tried updating drivers, reseating, going to hdmi (currently DP) with no luck. However in Computer management. The same error over 1000 times. nvlddmkm. Any idea's ?
GPU is less than a month old.
System
Eagle gigabyte 3060ti
5800x
corsair vengeance 16gb.
two x 1tb hdd
Samsung 960 evo nvme
750w psu
Water cooled.
Proud owner of a custom water cooled Ryzen 1400. 5800x
How old is the monitor?
My old monitor has the same issue (I didn't see any error messages though).
I opened it up to see if any capacitors died, but it changed nothing.
It takes a long time (1-5) minutes to turn on, flickering, and when it's on, it turns off sometimes.
That monitor is 12 years old 😄
Or maybe your cable is broken or not perfectly connected.
If you can, try a different cable and a different monitor.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
About a year but less than 2, just tried the tv same thing.
PC started hard crashing 😭
My condolences to you.
We can try to find the problem by replacing things until it works.
Replace cable.
Replace graphics card (Maybe borrow one from a friend)
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
Replace cable.
Yeah I've still got my 1060. I'll throw it in to see if it happens.
Replace cable.
1060 works fine, would of happened by now. So I used DDU to remove the drivers and happened within minutes again.
I know the DP works fine cause I tried HDMI.
23 minutes ago, Npiet1 said:
1060 works fine
So did it work fine or did the problem appear again?
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
1060 works fine, 3060ti happens within minutes.
So you still have warranty and the graphics card doesn't work like it should.
Send it back and let them repair it or give you a new one.
Or get your money back.
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
Yeah that's what I was thinking, other people had PSU issues just I'm gonna swap it over tomorrow, but if that doesn't work looks like a RMA
750w psu
750 W should be perfectly fine for the RTX 3060 Ti.
I wish you the best of luck, because I've read some crazy stories about gigabyte's support in this forum.
I've got a gigabyte RTX 2070 myself and never had any problems with it, but warranty stuff seems to be a problem...
My build:
CPU
CPU cooler
Motherboard
RAM
GPU
SSD
HDD
Power Supply
Case
Tested in my sons PC same thing.
Thankfully being aussie, RMA is done though the retailer. The store I bought it from reviews seem to be positive for RMA, so here's hoping for a good out come. So I've started the process. Hoping not for a 2 month turn around.
