Riser Cable
Hexxagone
Never used a riser cable before but want to for my new build, can anyone recommend a riser cable for a 3080ti?
Anything with decent shielding should be absolutely fine, something like this.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I am human. I'm scared of the dark, and I get toothaches. My name is Frill. Don't pretend not to see me. I was born from the two of you.
Do I need a PCIe 4.0 riser cable for a 3080ti?
You may need to set pcie to 3.0 in bios if using a 3.0 riser cable. 4.0 riser should work without config.  Performance difference between 3.0 and 4.0 is negligible.
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
So there will be a performance hit with setting a 3080ti to PCIe 3.0?
I was looking at this one at first but saw its PCIe 3.0
https://www.newegg.com/asus-model-rs200-rog-strix-riser-cable-bk/p/N82E16814997024?Description=pcie 4.0 riser cable&cm_re=pcie_4.0 riser cable-_-14-997-024-_-Product&quicklink=true
No
desktop
HTPC
So why do people buy PCIe 4.0 risers if 3.0 works with no issues
There can be compatibility issues with Gen 3 risers and Gen 4 motherboards.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
I have the new Asus Z690-E motherboard which I believe is PCIe 5.0 on the gpu slot, since CPIe 5.0 riser cables are not released yet, would I have to go into the bios and choose PCIe 4.0 since the 3080ti is 4.0 or would the motherboard automatically register that it is 4.0?
Based on how it went from Gen 3 to Gen 4, it may be hit or miss on if it will work correctly out of the box. Only way to know is to test.
"Black Out"
Ok thanks
I would set the PCIE speed to the cable speed so if its PCIE 3 manuallyt set it to that.
Motherboards on auto will try to run it at 4.0 due to the GPU and it can cause issues.
For me
Ryzen 5600x
gen 4.0
3070FE gen 4.0
NZXT h1 Riser gen 3.0
my PC would boot into windows and wokr OK, but as soon as I had any load on the GPU from games the games would crash.
some uses cant even get that far.
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
