Aftermarket GPU cooler: Some advice?
Imago
Hello everyone!
I hope someone can help me...
I bought a Palit GTX 1060 6Gb some time ago and now it's clear that its puny cooler can't cool the GPU properly. It's literally a small chunk of aluminium with a really small fan on it.
Somewhere I saw a couple of aftermarket gpu coolers (from Arctic and Raijintek) but they are really hard to find (always on restocking or not available), there are some other brands that makes stuff like that?
I even tried to use the cooler form another GPU that had about the same size and form but I have to cut&bend some part of it in order to fit in the 1060 and I don't want to ruin another GPU with the risk it doesn't work properly.
Thoughts?
My rig:
Case: Chieftec CI-01B-OP "The Cube"
Motherboard: Gigabyte B450M DS3H Rev.1
CPU: Ryzen 9 5900X
Cooler: ThermalRight Assassin King 120 SE with TF-4 Thermal paste
GPU: NVidia RTX 2070 Super Blower Style (HP OEM)
RAM: Corsair Vengeance LPX 3200 2x16
PSU: Itek BD700 DC-to-DC
If you want to do this cheap and your case has some room in it, buy a half decent tower cooler like the Hyper 212 or something like it, some thermal epoxy and small heatsinks on AliExpress for the memory chips, and mount the CPU cooler to the GPU. It's not that difficult, and will cool the GPU about as well as you could hope for.
even though the 1060 just has an aluminum chunk , if you redo it's paste and lock the fan at 100% what's it's load temp?
while probably somewhat loud the 1060 should be able to stay under80c if you really blast the fan on it. (trying to think of easy/free solution)
I can't find a proper way to mount a CPU cooler on the GPU, the mounting holes are totally different, exactly the thickness of the chips.
Do you know a good guide to do it?
I changed the thermal paste, I used the MX4 and I'm sure the application was OK but temps didn't change at all, probably just one or two degree less than before.
Even using the fan at 100% the situation isn't better: a lot of noice and the temp goes to 90° in two mins instead on one...
My rig:
CPU: Ryzen 9 5900X
You really need to be a DIY type person or have various spare parts to mount it securely. Its going to vary between other coolers.
CPU: AMD Ryzen 9 3950X   Motherboard: MSI X570 Gaming Edge Wifi   Case: Deepcool Maxtrexx 70   GPU: RTX 3090   RAM: Corsair Vengeance LPX 3x16GB 3200 MHz   PSU: Super Flower 850W
Is that an actual game load or just a synthetic load
I used some games and also FurMark to test it.
The games are GTA 5, Warzone and Heroes&Generals.
I did same tests on another 1060 and the temps are way better. Please spare me the "then use the other" because it's not mine. 😆
In the end, I simply have to buy another GPU, then?
My rig:
CPU: Ryzen 9 5900X
It's something I would avoid, that's why asked is someone could suggest me a good aftermarket GPU cooler.
I know there's some out there but I can't get them due to constant unavailability.
My rig:
CPU: Ryzen 9 5900X
Zip ties baby.
Did the card hit 80c in the game load or only furmark
