Help me decide on a case!
Solved by Krosis,
5 minutes ago, TVwazhere said:both are exactly the same case, just different external paneling.
Personally I'd pick the P600S for the possibility of better airflow by removing the front plate as needed, whereas the Evolv X you're just stuck with it as is.
That's exactly why I am so indecisive. I would like the airflow options of the P600s, but I really like that case in black color, which is currently out of stock here.
I think I might just suck it up and go with the grey or white. I have always liked the Evolv X, but i think P600s is more versatile,
