AM4 socket
3x NVMe M.2 slots at full speed for RAID
As many possible SATA slots possible, not a game changer, have HBA cards/addon for more storage
4x DIMM slots (64gb)
ATX or larger preferred
Im out of the technical game lately and dont have alot of time to research, trying to stay away from HEDT
Thanks for your time!
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
https://linustechtips.com/topic/1380452-need-a-motherboard-with/
so 3x pcie gen 4x4
i think most boards are pcie gen 4x4, only two slots available on the board as:
- 4 lanes from CPU to NVME directly
- 4 pcie 4.0 lanes from cpu to chipset to NVME, which, if i understand correctly, shares bandwidth with the rest of the device that runs thru chipset, ie, pcie slots that runs off of the chipset, sata drives and what not
how about using NVME expansion cards?
-sigh- feeling like I'm being too negative lately
1 minute ago, Moonzy said:
so pcie gen 4x4 3 lanes each?
how about buying NVME exampansion cards?
I can
Doesnt necessarily have to be 4.0 (unless it saturates the bandwidth)
Recommendations?  Again, totally out of the game lately, but need to finally push the button on an editing rig better than my 3600.
I already plan on slapping HBA card in to expand storage
Can I raid off a addon card and 2 slots on board?  My brother will be doing all the RAID stuff, Im betting with the right OS its easy but I will be using Win 10
honestly, same, but im just saying what i know
a quick googling of the x570 strix shows 2 m.2 slots as i've predicted
i chose strix because there's 2x pcie x16 slot from the CPU (x8 both or x16 one of them), so you can get more bandwidth from the CPU to run add-in cards
non-SLI boards have only 1x pcie x16 slot from CPU, which you'll probably use it for GPU, i assume
hmm... software raid probably? @Windows7gemight know better about this
maybe someone else will know a board that has 3x m.2 slots, maybe wait for more answers
Even if you find such a board, I'm not sure you can do raid with 3 nvme drives.  I'm not sure you can make raid between drives on pci-e lanes coming from cpu and drives on pci-e lanes coming from cpu.
You'll get one m.2 nvme from cpu,  and then chipset can provide 6-10 pci-e lanes which can be routed to pci-e slots or m.2 connectors.  That's why most b550 motherboards will have an additional m.2 nvme drive and x570 motherboards may have 2 extra (because the x570 chipset has a few extra pci-e lanes)
On some motherboards, they disable a couple of sata ports when you install a 3rd m.2 ssd, because there's not enough pci-e lanes.
There's some exceptions like Gigabyte B550 Aorus Master, which splits the pci-e x16 slot into pci-e x8 and 2 m.2 nvme connectors... if you install a ssd in either of those connectors the video card runs at pci-e x8
Thank you very much for your time, trying to figure out a one stop convenient package but willing to run add on cards (already bought the HBA recommended 🙂 )
Thanks for this info
I know nothing of raid, just looking for quickest (for the investment) video editing times.  Right now my 3600 system hangs up to much while trying to view in full resolution, adding multiple layers etc.  So am looking for the FASTEST NVMe setup.
Basically CPU 5950x
64gb CL14 ram (maybe CL16, not sure Ill notice a diff)
RTX 2060 (migrate or get a 3060 not sure yet, the 2060 may stay with the current PC)
All the storage, going to use this as a multi-use system (in the evenings it will be copying my server data while I sleep that is offsite) but this storage will be HDD's
any particular reason not to go HEDT? would alleviate a lot of your headache as your requirement is pretty much HEDT
Cost of mobo, and CPU.  NOT off the table, just trying to maintain a sensible budget (didnt know Id be video editing this year or I would have never invested in a 3600 system lol)
If its not something that exists I can up the budget, once I build this, its got to last me 5 years.  HEDT will do that as well but at alot more input cost (CPU, mobo)
just get a b550 board with decent VRMS (basically most of 100 dollar+ boards) and use expansion cards.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
I very much so second this. Save you money on buying expensive boards that still don't have the full feature set and you can easily get a many pcie slot b550 board.
And where you put those expansion cards
On cheap b550 cards, you have the pci-e x16 slot for graphics and 1 or 2 pci-e x16 slots which are pci-e x4 only ... so you can't use
It's not as simple as that... some research is required.
Sorry. 11hr day job. 😭
It can depend on the Software RAID implementation and what HBA's are used to connect the SSD's.
If they're direct-link and the plan is to bifurcate the slot so long as the slot doesn't go through the chipset nothing stops you from using an onboard slot then add-in cards. To the CPU it would all be seen the same so long as the onboard slots themselves also don't go through the chipset. This would introduce heavy bottlenecks.
Note though with Windows your only real option is Storage Spaces and you cannot boot to a Storage Space volume.
Also note with Windows if you go Parity RAID expect lower than ideal write performance due to the overhead associated with parity calculations.
If you're going GNU/Linux or UNIX you could use ZFS. It handles parity calculations better than Windows Storage Spaces. It can also be used as the boot volume so long as ZFS is supported at the distro installer menu such as on FreeBSD 13.0, or FreeNAS (I assume the option has been carried over to TruneNAS CORE), It's also available on PROXMOX (Debian based) if you're looking to create a hypervisor. It may also be available on Ubuntu Server/Desktop but I haven't particularly tested or verified it.
