how are hard drives and ssds contain things that were delete?
adarw
i dont get it, i understand how both work but why do they keep deleted things yet have the same amount of storage as before.
|:Insert something funny:|
A quick format doesn't do what the above link explains, it just creates a new partition and continually overwrites the exitsing data.
^that
If you want the data permanently removed you need to overwrite it. I'll list a couple of software that will help you.
To delete all data on a drive: Darik's Boot and Nuke. https://dban.org/
You make a bootable CD/USB and boot to it, it will completely wipe all data by overwriting it.
If a nuke is a bit much, then use Eraser to overwrite certain files and folders. https://sourceforge.net/projects/eraser/
A stupid question but
Could you delete all your data permanently via using a zip bomb to overwrite all the old files?
What is a 'zip bomb'?
The tools I provided will work.
I think zip bombs are extremely large zip files when you try to open them
Might be usefull if i try selling any storage in the future, thx for the tool reccomendations
Sounds even less than practical... no problem.
