Can front USB ports handle sustained transfers?
dizmo
I'm trying to transfer data from one external HDD to another, and they just gave up the ghost about 25% of the way through. It also disabled the USB port that my WiFi dongle is attached to, but the keyboard still worked.
I had to restart to gain full function.
Do front USB ports just not have the stamina to handle sustained writes? It's just shy of 2TB.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Could be your boards power saving features that's some how turning off the USB ports.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
I thought that too but I checked and it didn't change anything.
I almost think it has to do with overheating. The only things that disconnect are the items transferring or receiving data. Le sigh. Going to be so much more of a pain in the ass to transfer everything over now.
That sucks, try another USB port like the ones directly on the back. Can also take a look at the USB controllers/drivers in device manager. There may be a power management tab. In that, uncheck "Allow the computer to turn off this device to save power".
Can also try the adjusting the USB setting in Power Management located in control panel
AMD ThreadRipper 2!
