Corsair ml140 RGB vs BeQuiet pure wings 2
Gohardgrandpa
Front mount is a thing. The fan choice is my question.
No cpu mobo or ram atm
2tb wd black gen 4 nvme
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Gigabyte m34wq 3440x1440
Xbox series x
Your only option is in the front. Ideally, the tubes to go between the radiator and pump will be on bottom.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
So after looking up fan stats, here's what I've found.
Be quiet pure wings 2 140mm- 100% speed is 1000rpm, 61.2cfm at 18.8dba
I have 3 of these fans
Corsair ML140 RGB pro- 100% speed is 1,200 rpm, 55.4cfm at 20.4dba.
I have 4 of these fans.
Do you think I'd be better off running 2 of the Be Quiet fans on the rad and using 3 of the Corsair fans in the case as exhaust?
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Xbox series x
I don't think you'll be able to put 120mm fans on that AIO, so use the Corsair 140s that came with it.
Project Hot Box
Oppbevaring
My be quiet fans are 140mm and I've got 3 of them.
Looks like I'm gonna have a long night tonight. I'm gonna try each fan on the radiator and see what does better
2tb seagate hdd
Corsair rm750x
Be quiet 500dx
Xbox series x
fan stats are false so test it.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
