Laptop speaker lost its sound quality...
Try EQ in VLC. It allows a large 40 db difference between two frequencies, and should allow you to test bass response. Try setting the equalizer preamp to -12 so you don't over power the speaker and learn at what volume causes the distortion.
Setting system volume to 75% or 50% may help also.
You could also try slowing down your music library using vlc, by disabling time stretch.
Timestretch allows the pitch to be maintained in faster speeds, which is great for speech, but slower speeds cause a poor sound quality.
Go into vlc settings
Audio / save playback speed
Advanced / uncheck timestretch
I bring this up because I am obsessed with it, but because dropping speed also reduces the bass note frequency. So instead of being 60 Hz bass note, playing at 80% speed is now a 48 Hz bass note.
Combine that with stepping up the 31 Hz slider in vlc equalizer, you can test what frequency of bass works, and what distorts, all the while hearing a new way to enjoy your music, in a new tempo.
I hope you can work around the hardware issues through software, and keep the speakers that you have for many more years. I have a set from, I don't know exactly, but well over 10 years, and they still work great.
