10G LAN question
Go to solution Solved by mariushm,
Yes, you can. You just set different local IPs on each computer , ex 192.168.0.201    and 192.168.0.202  and same subnet mask, ex. 255.255.255.0
But it would be better to go with fiber network cards - if the computers are close to each other, let's say 3-5 meters, you can get a passive DAC cable for around 10-20$. Also, the cards are often cheaper on the used market.
I'm going to be running two machines, with one being a server, the other being my rendering/gaming machine. There will be times when I have to flush data off a 2TB or 4TB NVME gen 4 SSD to the other machine, going to another, matching 2TB or 4TB NVME gen 4 SSD. Both machines are going to be Win 10 Pro, eventually upgraded to Win 11 Pro.
If I got a pair of 10G NICs, could I just run a Cat6 cable from one machine to the other, with my internet still running through the onboard gigabit to my router? I'm trying to not buy a massive, expensive 10G switch, which will have tons and tons of ports that I have no use for, put extra load on my UPS, and just waste tons of room that I just don't have to begin with. 😧
"Don't fall down the hole!" ~James, 2022
"If you have a monitor, look at that monitor with your eyeballs." ~ Jake, 2022
https://linustechtips.com/topic/1367133-10g-lan-question/
yup you can do that. Just setyp a subnet between them.
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14946222
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14946225
I literally do this in my own.  The whole apartment is on a 1gig network that has internet and allows any communication between any PC.  The main desktop and main UnRAID server each have an additional 10gig NIC and are directly linked over a CAT6A cable.  You do have to manually set their IPs and also in Windows it can help to configure the HOST file to which IP you'd prefer the names resolve to, or sometimes Windows will randomly select which NIC the name resolves to and you want it to always be the 10GIG for those two machines.
Desktop: Ryzen 9 3950X, Asus TUF Gaming X570-Plus, 64GB DDR4, MSI RTX 3080 Gaming X Trio, Creative Sound Blaster AE-7
Gaming PC #2: Ryzen 7 5800X3D, Asus TUF Gaming B550M-Plus, 32GB DDR4, Gigabyte Windforce GTX 1080
Gaming PC #3: Intel i7 4790, Asus B85M-G, 16B DDR3, XFX Radeon R9 390X 8GB
WFH PC: Intel i7 4790, Asus B85M-F, 16GB DDR3, Gigabyte Radeon RX 6400 4GB
UnRAID #1: AMD Ryzen 9 3900X, Asus TUF Gaming B450M-Plus, 64GB DDR4, Radeon HD 5450
UnRAID #2: Intel E5-2603v2, Asus P9X79 LE, 24GB DDR3, Radeon HD 5450
MiniPC: BeeLink SER6 6600H w/ Ryzen 5 6600H, 16GB DDR5
Windows XP Retro PC: Intel i3 3250, Asus P8B75-M LX, 8GB DDR3, Sapphire Radeon HD 6850, Creative Sound Blaster Audigy
Windows 9X Retro PC: Intel E5800, ASRock 775i65G r2.0, 1GB DDR1, AGP Sapphire Radeon X800 Pro, Creative Sound Blaster Live!
Steam Deck w/ 2TB SSD Upgrade
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14947215
Yeah, it sounds good to me.
When I move, hopefully, in a few months, I'll be getting a place that has space for rackmount, and I'll invest in a switch and actual server stuff then. But for now, I just want to be able to move huge quantities of stuff from machine to machine without having to wait for hours and hours to do it @__@
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14947219
And the parts are not expenisive now.  Copper 10gig NICs are like CAD$100 these days.  The real expenses is a 10gig copper switch, but once those come down, I'll retire my 1gig switches and just have it all as one thing again.
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14947222
You can buy dual 10g fiber cards for $25-50 each, for example here's one for $35 : https://unixsurplus.com/solarflare-sfn6122f-dual-port-sfp-10gbe-pci-e-high-profile-server-adapter-card/
DAC cables are cheap, 15-40$ for 3 meter ones :
3M SFP+ 10GbE Direct Attach Cable Twinax DAC
Cisco 3M Twinax 3Metre SFP+ 10GB/s 10GbE Direct Attach Cable DAC SFP-H10GB-CU3M
fs.com also has loads of them : 10Gb SFP+ Cables, SFP+ Twinax DAC Cables - FS Germany
The site that sells the $35 cards also sells a get a bundle with two intel cards and a dac cable  for $170 : https://unixsurplus.com/bundle-x520da2-intel-dual-10gb-w-2x-dac-direct-attach-cable-included/ - not really a great value but still cheap.
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14947242
Right, I don't see the long term appeal of this.  That's USD$170 for the 'Kit' meanwhile you can just get two copper 10gig cards for like USD$90 each + the cost of some CAT6A for whatever length you want.  You can then reintegrate that with 10 gig copper switching in the future as the cost of copper switching comes down. It will also integrate with 2.5 or 5 gig switching if you don't mind the speed drop.  You basically saved the cost of a delivery order of pizza but built something far more restrictive in terms of expansion and future proofing.
The 'cheap' you suggest is pitifully small savings at a significant cost of flexibility.
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14947253
The Solarflare cards I linked to are $35 each, and they're dual 10gbps cards, and they have drivers built into windows, linux and other operating systems..
If your cables are less than 30 meters, you can easily use ethernet to sfp+ transceivers to plug your 10g ethernet cable into a sfp+ port, if the switch you have has no 10g ethernet ports.
If it's 2 computers in the same room, it's really cheap way of connecting those.. you get two cards for the price of a single 10g ethernet card.
As for the other benefits ...
SFP+ network switches are much cheaper... try getting a 16 port or higher 10g ethernet switch at reasonable prices. You can get 48 sfp+ port switches for same price. Also you can get QSFP switches (40gbps ports which can be divided into 4 x 10gbps ports) or QSFP28 switches (100 gbps divided into 4 x 25gbps or 4x10gbps) so you could reuse the fiber in the future to get higher speeds.
You can get transceivers to convert RJ45 to SFP+ if you have 10g ethernet cards
You can use transceivers + fiber cable as long as you want.
Ethernet to SFP+ transceiver (they used to be around 20-30$ each) at around $40 : https://www.amazon.com/10GBASE-T-Transceiver-Copper-Compatible-GP-10GSFP-T/dp/B07HK871RD/
SFP+ Transceiver (LC Duplex) from 20$ : https://www.fs.com/de-en/c/10g-sfp-plus-63?sort_order=price&count=24&settab=two
They're 10$ or less on ebay ex. 6$ each : https://www.ebay.com/itm/274844675396
LC-LC fiber (5$ for 1m, $10 for 5m, 22$ for 15m ) : https://www.fs.com/de-en/products/40180.html?attribute=6741&id=270331
Can be found cheaper definitely.
Good cat6a cable, proper solid core pure copper cat6a cable, will cost you at least 200$ for a 1000ft / 300m roll, here's some examples :
https://www.amazon.com/SolidLink-1000ft-Listed-Conductor-Ethernet/dp/B0742R9642/
https://www.amazon.com/1000ft-Unshielded-Twisted-Ethernet-trueCABLE/dp/B07FK88PX9/
https://www.amazon.com/Ethernet-Gigabit-Unshielded-Twisted-iTechCables/dp/B07XN8CN7Y/
so it's not that much cheaper, plus it's thicker, harder to route, more susceptible to noise and other issues.
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14947340
That's a *whole* list of parts and extra components to make your idea cheaper when copper Switches will just keep getting cheaper and you can just plug them into any existing comedy hardware instead of this miss mash of enterprise grade adaptations.
https://linustechtips.com/topic/1367133-10g-lan-question/#findComment-14947350
