Are Magnetic Screwdrivers safe when building a PC?
Solved by Skiiwee29,
Yes, they're fine. I have been using Magnetic screw drivers for as long as I can remember. Heck, the iFixit kits are all magnetic as well. I use one that came with my Cryorig R1 Ultimate cooler as well as some run of the mill cheap ones you can get at your local hardware shop. Just make sure they're long enough to reach some of the areas that can be a pain or short enough to clear tight spots. You will need a combination of Phillips 0, 1 and 2 heads to complete the job on most builds.
