CPU with 3MB Cache and higher frequency or 4MB Cache with lower frequency
Hi, I want to upgrade my PC CPU for online school and just light gaming on a low budget. I want to upgrade it from Pentium to Core i3. My motherboard is LGA 1150 socket with H81 Chipset. After I searched the online store I got 2 choices. i3 4170 3.7GHz with 3MB cache and i3 4330 3.5GHz with 4MB Intel® Smart Cache. Should I choose i3 4170 0.2Ghz higher frequency and Integrated Graphics Intel® HD Graphics 4400 or i3 4330 with 1MB larger Cache and Integrated Graphics Intel® HD Graphics 4600? The price of these two CPUs is the same, which is $41.55 (Convert from IDR 600,000 to Dollar)
Sorry, I'm new user in Linus Tech Tips and newbie in PC Components
Specifications of the 2 CPUs Above (Source ark.intel.com)
[i3 4170] https://ark.intel.com/content/www/us/en/ark/products/77490/intel-core-i3-4170-processor-3m-cache-3-70-ghz.html
CPU Specifications
# of Cores
2
# of Threads
4
Processor Base Frequency
3.70 GHz
Cache
3 MB
Bus Speed
5 GT/s
TDP
54 W
Supplemental Information
Embedded Options Available
No
Datasheet
View now
Memory Specifications
Max Memory Size (dependent on memory type)
32 GB
Memory Types
DDR3-1333/1600, DDR3L-1333/1600 @ 1.5V
Max # of Memory Channels
2
Max Memory Bandwidth
25.6 GB/s
ECC Memory Supported ‡
Yes
Processor Graphics
Processor Graphics ‡
Graphics Base Frequency
350 MHz
Graphics Max Dynamic Frequency
1.15 GHz
Graphics Video Max Memory
2 GB
Graphics Output
eDP/DP/HDMI/DVI/VGA
Max Resolution (HDMI)‡
4096x2304@24Hz
Max Resolution (DP)‡
3840x2160@60Hz
Max Resolution (eDP - Integrated Flat Panel)‡
3840x2160@60Hz
Max Resolution (VGA)‡
1920x1200@60Hz
DirectX* Support
11.1/12
OpenGL* Support
4.3
Intel® Quick Sync Video
Yes
Intel® InTru™ 3D Technology
Yes
Intel® Clear Video HD Technology
Yes
# of Displays Supported ‡
3
Device ID
0x41E
Expansion Options
Scalability
1S Only
PCI Express Revision
Up to 3.0
PCI Express Configurations ‡
Up to 1x16, 2x8, 1x8+2x4
Max # of PCI Express Lanes
16
Package Specifications
Sockets Supported
FCLGA1150
Max CPU Configuration
1
Thermal Solution Specification
PCG 2013C
TCASE
72°C
Package Size
37.5mm x 37.5mm
Advanced Technologies
Intel® Turbo Boost Technology ‡
No
Intel vPro® Platform Eligibility ‡
No
Intel® Hyper-Threading Technology ‡
Yes
Intel® Virtualization Technology (VT-x) ‡
Yes
Intel® Virtualization Technology for Directed I/O (VT-d) ‡
No
Intel® VT-x with Extended Page Tables (EPT) ‡
Yes
Intel® Transactional Synchronization Extensions
No
Intel® 64 ‡
Yes
Instruction Set
64-bit
Instruction Set Extensions
Intel® SSE4.1, Intel® SSE4.2, Intel® AVX2
Idle States
Yes
Enhanced Intel SpeedStep® Technology
Yes
Thermal Monitoring Technologies
Yes
Intel® Stable Image Platform Program (SIPP)
No
Security & Reliability
Intel® AES New Instructions
Yes
Secure Key
Yes
Intel® Trusted Execution Technology ‡
No
Execute Disable Bit ‡
Yes
[i3 4330] https://ark.intel.com/content/www/us/en/ark/products/77769/intel-core-i3-4330-processor-4m-cache-3-50-ghz.html
CPU Specifications
# of Cores
2
# of Threads
4
3.50 GHz
Cache
4 MB Intel® Smart Cache
Bus Speed
5 GT/s
TDP
54 W
Yes
Datasheet
View now
32 GB
Memory Types
2
25.6 GB/s
Yes
Processor Graphics
350 MHz
1.15 GHz
2 GB
Graphics Output
eDP/DP/HDMI/DVI/VGA
4096x2304@24Hz
3840x2160@60Hz
3840x2160@60Hz
1920x1200@60Hz
DirectX* Support
11.1/12
OpenGL* Support
4.3
Yes
Yes
Yes
3
Device ID
0x412
Expansion Options
Scalability
1S Only
Up to 3.0
16
Sockets Supported
FCLGA1150
1
PCG 2013C
TCASE
66.8°C
Package Size
37.5mm x 37.5mm
No
No
Yes
Yes
No
Yes
No
Intel® 64 ‡
Yes
Instruction Set
64-bit
Idle States
Yes
Yes
Yes
No
Yes
No
Yes
i5 or Xeon may be a better option. Likely can find a used one for a good price.
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
36 minutes ago, Electronics Wizardy said:
Can you get other cpus?
HOw about a xeon e3 1220 v3? Should be cheaper, much faster(its a quad core). And works in almost all lga 1150 h81 boards.
Correct me if im wrong but i think the 12x0 cpus dont have igpu, though the 12x5 cpus do have igpu
But then again if the igpu counterpart is 15$ or mlre above the non igpu counterpart then might aswell just find some cheap low end hd 5450 or hd 6350, still dx11 so shouldnt run into any issues with programs
Yup thats right, not igpu on the 1220.
But a e3 1225 v3 isn't much more on ebay, and the igpu on those is much faster than a 5450 or similar so thats what id get if you need a igpu.
CORE Beats Cache
+100Mhz vs +100Mhz independently.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
Yes Xeon is cheaper $2.42 and already quad core. But there is no IGPU and I have to buy separately. Meanwhile, to match the i3 4170 or i3 4330 IGPU I have to spend more budget. And that much budget does not include upgrading 1 piece of RAM from 2 GB to 4 GB (1 other slot already has 4 GB).
Thanks for the answer!
I only have 2 choices for Xeon and i5 because there are no other series in my country's online store. For i5 4690 the price is higher $24.24 (Original price $65.79) and for Xeon E3 1220 V3 it costs $2.42 less (original price $39.13) but no IGPU. My plan is just to upgrade the CPU and RAM with a low budget. For GPU it could be next month or next year. Meanwhile, the CPU that I use is damaged, I'm afraid that next month's exam will suddenly turn off my PC and all answers will be lost.
25 minutes ago, SkilledRebuilds said:
CORE Beats Cache
It only affects performance very little, right?
What do you mean by the cpu is damaged? CPUs don't fail often, and the motherboard or ram is much more likely to be the issue here.
In the past I've tried to delid for experiments and the result failed. The memory controller can only recognize 1 RAM slot. When I plug in 2 ram buzzer it beeps long. Before it was delided there were no problems whatsoever. I'm afraid when I use it my PC suddenly turns off
Id really try to get a e3 1225 v3 on ebay then, Should be in your budget, and much faster than these i3 options.
Yes, it's true but shipping costs from abroad to my country are 30% - 50% of the price of the CPU itself
But even with shipping, those chips are about 30USD here, so they should fit in your budget. Id take anouther look.
Yes thanks for helping me. Maybe I'll buy it
