How to solve the bad sector problem in my laptop
If it's a mechanical hard drive ...
Bad sectors are areas of your drive's platters that have problems and can't reliably store data anymore. The drive moved data from those areas in other parts of the drive and keeps going, but those areas can increase over time and there may be other areas with problems yet undiscovered by your drive.
When an area is weak, the drive's heads has problems reading the data, so it has to read the same track several times in order to determine if what it reads is correct or not and that slows down your hard drive when it reads the data from such areas.
Sometimes bad sectors are incorrectly detected when there's power failures or mechanical shocks and these bad sectors can be recovered using specialized software, but to do this process, all the data on the drive would be erased... so you need to copy the stuff to another drive before you attempt to "fix" such incorrect bad sectors.
Basically, your only option is to replace your mechanical drive with something better, and I recommend buying a SSD as it has no moving parts and consumes a bit less power, and it's much faster than a mechanical hard drive.
