monitor advice HDR or 12 Bit Monitor?
3 minutes ago, BilderEsser69 said:Seems like I messed somthing up there... I somehow remembered the Asus ProArt PA27AC can do something with 32Bit AdobeRGB or something, not sure tho...
I meant 10 (or 12) bit per channel.
Probably that it covers a certain percentage of the AdobeRGB color space.
3 minutes ago, BilderEsser69 said:With what you said about HDR displays emulating 10 bit colors etc, my question is: instead of using an HDR display, can I get the same color range/depth with a monitor without HDR but with 10 bit per channel?
HDR means the monitor has a High Dynamic Range (i.e. large difference between darkest and lightest color it can display). Something like HDR1000 means it can produce at least 1000 nits of brightness. 10 bit color depth per subpixel means the display can show 1.07 billion different colors instead of the more typical 16.7 million.
HDR monitors typically have 10 bit color depths. But the technologies are not the same and can't emulate one another. Also some monitors that claim to have a 10 bit color depth actually have 8 bit, but use a technology called frame rate control (FRC) to emulate 10 bit color depth by quickly switching between colors each frame.
3 minutes ago, BilderEsser69 said:If I run a game on a 10 bit monitor without having HDR enabled in-game, do I still see the same image as I would do with an HDR display? Surely something about the shaders or color profile is changing if I enable HDR, right?
I try to get the advantage of HDR without actually using HDR, does that make sense?
Not really, no. As I said above HDR means you get more dynamic range. The difference in brightness between the darkest pixels and brightest pixels is higher than normal. This is not the same as (only) having more color depth.
