Monitor Compatability
TheLimitlessGuy
I have a Question.
Is it possible  to have a alienware aw3420dw lunar light triple monitor setup
Does Alienware Monitors work for a custom pc?
Edited by GDRRiley
MOD: removed formating
Possible yeah totally. Practical? Not at all.
But you did not provide any specs of your system so I cannot answer if it will work for you without that information.
==Moved to displays==
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
5 minutes ago, jaslion said:
Sure that will work.
Do keep in mind that most games won't work on this setup if you use surround gaming or when they do they'll be horribly stretched.
I will be using one for chat and the other for info on my simulation games
Bit of a waste to get a very expensive monitor for that when a cheap 120$ one could do it just as well but you do you.
Do make sure your games support it.
