I don’t think you want this case.
unless there’s airflow that I can’t see, (video won’t load), there’s actually some front airflow, but it’s only this99F44E46-3E1B-407A-9447-EEAD43F3B5D3.jpeg.fc5a7c117e0f53c98284bb5737255181.jpeg
it might as well be a h510 for how shitty the airflow will be, your components are going to start cooking
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
ye that did cross my mind, looks like you're corect with the case there, looks identical.
Thanks!
It's Specifically the H510 Elite
Thanks!
The Air vents are on the rear side of the case
NZXT H510 Elite white metal side
Problem is, the stock fan configuration doesnt end to be well placed to take best advantage of the side vents; they need to be moved away from the glass which defeats the purpose of "SHINY RGB LIGHTS" so people never do it.
