Need help with CCNA2 configuration
Solved by Lurick,
1 minute ago, spree said:On R1,
Ip route 172.16.31.0 255.255.255.224 10.1.1.2
the 172 address is the adress which R1 needs to get to R3's LAN, correct?
What does 10.1.1.2 address represent? The connection which R1 is connected to R2?
ip route (destination network) (destination mask) (next hop)
172.16.30.0 255.255.255.224 is the subnet you're trying to reach
10.1.1.2 is the next hop, in this case the IP address of the directly connected interface on the next router
