USB Hub connection cutting out
Solved by RGProductions,
Just now, greenlotad said:Do you think powering the hub with an ac adaptor would provide enough power for the hard drive? If possible, I'd like to do that. This is only a minor problem, but the usb cable on the ext. hard drive is very short, so placement is a bit inconvenient if it's plugged into the motherboard.
It should probably work (depending on the specific hub) but it would likely be cheaper to get a longer cable for your external hard drive
