question about +12V +5V and +3.3V readings.
GlaZe08
Go to solution Solved by Levent,
Hello!
Noticed in HWmonitor that my values on these are slightly higher than than what they should be. Is this an issue?
https://glaze.s-ul.eu/oRE75ef1.png
Completely normal and totally fine.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
16 minutes ago, GlaZe08 said:
Alright, was just curious coz i've been experiencing some freezes on my new built system, so im just trying to rule stuff out
What kind of freezes?
Any BSoDs?
Mouse and keyboard still have power?
If you're playing sound, does it keep going if the screen stops?
elephants
Any BSoDs?
Made a new post about it just now,
