Lav XLR Mic not working with Audio Interface.
Sir Asvald
I am need of some help. I have recently bought this lav XLR Mic and my audio interface is the u-phoria umc204hd and it has phantom power. I am not sure why it is not working at, If things helps, I am on Windows 10 pro 20h2 upgraded last month ago.
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
Anyone?
Amazon listing indicates it requires a battery, did you put the battery in?
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
It say it requires, one but then it says it doesn't because it's XLR, powered by a phantom device, which my device has.
And obviously it's not working with phantom so did you try using the battery?
@rice guru
And if you're powering it off of phantom power, is phantom power turned ON?
It's DOA. I've tested it on another Audio interface, doesn't work. So I am returning it. Also, there was no battery included with it, nor there was no option to put in a battery..
May I recommend not buying audio equipment off amazon. All they sell now is Chinese imported crap and since the deal with Behringer Amazon has been removing any products which compete against Behringer products. So its just a terrible place to buy audio equipment off.
https://www.bax-shop.co.uk/lavalier-microphones/samson-ql5cl-mini-lavalier-condenser-mic-with-adapter
Bit more then what you original had but its a brand I would be willing to trust. From a UK supplier who I would trust.
Well I placed another order for another one. Hopefully it works, if not, then I'll look some other stores.
