Which PC Case Fans to use?
Lecom1020
Go to solution Solved by Orian Pax,
glad i could help, all the best.
2 of my preinstalled fans died and now im replacing all my fans in my system but i dont know which ones to get
case : be quiet silent base 802
cpu 5950x with a top mounted 360mm radiator
gpu rtx 3090
mainboard x570-f gaming
my problem now is which fans to choose (140mm) where to plug them in (mb doesnt have enough 4pin headers it used the standart 3pin fan hub included with the case)
would prefer something with good performance
silent is not the most important thing for me but nothing to extreme please
budget around 170€ = ~200usd  (5 case fans)
+1 for arctic p12's/p14's
ek vardars if you want rgb.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
Arctic P14 PWM
be quiet! Silent Wings 3 PWM
Scythe Kaze Flex 140 PWM
BTW, Silent Base 802 is still under warranty! It can't be older than 6 months.
1 hour ago, --SID-- said:
Arctic P14 PWM
i know i already talked to bequiet/my vendor  they offered me replacement fans  but i wanted to change them for pvm fans anyway and they gave me the value for the fans als a gift card
i dont know much about fan hubs i could get a nearly new corsair commander pro for about 15-20€ would that be ok or a different one
just out of curiosity a buddy of mine has some Corsair LL140mm that he wants to sell cheap(im not really a fan of rgb so i wouldnt plug in the led cable)  or are they bad also i could get some
NF-A15 HS-PWM   or   NF-A14 PWM from noctua
atm im looking for the silent wings 3 they would match the case the best
gpu rtx 3090
if you got money to blow Noctua's the way!
this video covers all the fans recommended to you by others too.
where? how? i would like to know more about this!! plz (that's cheap and really good offer)
if it's free then plz take them too.
from the buddy that would sell me the fans he has a corsair 500d rgb se which included a commander pro that he doesnt use because he already had one from a special offer that a german store had (6fans and as an extra you could get a commander for 20€ after that he bought the case )
what im wondering is the video you postet there is a comparrison of 120mm fans im getting 140mm fans
i would like to share something about, i should have done that earlier,
you can add phanteks halos later on noctua's (i am planning to that with mine, i too don't care about rgb at all this is just to hide that brown and beige until black version of those fans comes in)
https://www.amazon.com/vdp/823b298bc79c4ee1b9b34a8ad257774e
ohhhhhh
then arctic's p14 i way to go but noctua's those fans can not only match but even surpass 140mm fans in real world performance/cooling. hold up plz
plz  go through this, you won't be disappointed, i had that query too.
Edit -
bit more info -
 (honestly with 5-6 nf-a12*25 and commander pro for 20€, it's a steal, at least for me. they,fans and commander pro are too expensive here above msrp.)
and one thing i would like to point out is that fans many fans start to make noise after 2-3 months and i have never heard about that noctua doing.
on the other hand to tackle this problem i could get thrice as many fans of arctic's p14s.
hmmmm interesting info about p14's
nice comments here too -
plz go through comments of these too. one always get to know something out of them
3 minutes ago, Orian Pax said:
edit above
done with your thread now looking into the video  in your thread woodenmarker said it would be better to go with the a12 when you get 1 fan more in your thead it was 4x120 or 3x 140 in front  your case supports up to 480 mine only up to 420 in front so woudnt it be better to go a14 in that case?
yes it would be great if it supports upto 420mm.
with that said arctic's p14 might be better to consider here (performance per buck)
what im getting out of the reddit post you linked ist that arctic fans are basicly performing the same or simmelar  only that you have a slight change that they have a bit more noise/ vibrations (if your unlucky (lottery))
yes and p12s have some sort of humming sound which p14s doesn't.
at least majority of people who posted this problem were the owners of p12s.
in case you don't want to save money and go with ur budget you can't go wrong with either of the 140mm fans,
(performance wise, color wise it's subjective)
and i have heard only positive things about noctua's after sales service.
i have yet to come across a bad or very bad review of noctua's service
1 minute ago, Lecom1020 said:
so the P14 PWM PST Value Pack would be the way to go if one or to are bad no problem for the price?
give me a minute or two, i would like to take a look at pst versions,
and there's also an edited post right above about after sales service of noctua
i would say that's really cheap and a very good deal. so yeah i would say yes!
(info about PST here, just in case -
i looked on arctics side the pst is the power sharing technology the normal p14 said is only a 3pin the p14 pst is the only pvm version i could find
