Ram running at wrong speed after cpu and ram upgrade
Jetta
got a matching set of corsair vengeance ram (2x8gb 3200 MHz ddr4) and task manager is showing 1600 mhz. this happened with my old ram but since it was mismatched i figured it was that. i know the infinity fabric is at 1600mhz but task manager should be showing double the infinity fabric. In the bios is change the "dram frequency" from auto to 3200mhz and enabled XMP profile 2. (i also tried none and profile 1 but both gave the same results.
i also have a new cpu which when i upgraded caused this problem. i went from a Ryzen 5 1400 to a Ryzen 5 3600 and my mobo is a msi b350 m bazooka which did need a bios update to a beta version\
i had this problem a little bit ago (that's when i only had upgraded cpu) and made a forum post <--link
Memory is DDR (Double Data Rate). Subsequently, 1599MHZ x2  = 3200MHz. This means that there is nothing wrong here. You are just expecting to see different numbers, which can't really happen.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
