Ram running at wrong speed after cpu upgrade
Jetta
I just updated from a Ryzen 5 1400 to a Ryzen 5 3600. My mother board is a "msi b350m bazooka" so I had to update the bios and while at it update drivers and now my ram which is 2x8 @ 2400mhz is now running at 1200mhz. I went in bios and changed the DRAM frequency to 2400mhz instead of auto. any ideas of troubleshooting steps
important note: the ram sticks are mismatched brands BUT they both run at same speed and same size
XMP is enabled and is on profile 2
3 minutes ago, Jetta said:
I just updated from a Ryzen 5 1400 to a Ryzen 5 3600. My mother board is a "msi b350m bazooka" so I had to update the bios and while at it update drivers and now my ram which is 2x8 @ 2400mhz is now running at 1200mhz. I went in bios and changed the DRAM speed* to 2400mhz instead of auto. any ideas of troubleshooting steps
*I don't remember exact name of setting. will change soon to actual name
Try setting the XMP profile.....
Ryzen 5 2400G -B450M DS3H Motherboard (Gigabyte) - 16GB RAM (CL 16, 3000MHz) - 240GB SSD (Kingston) - 1TB HDD(Seagate) - 450W PSU (Corsair)
where do you read 1200MHz, because DDR stands for double data rate, do 1200MHz = 2400MT/s (or commonly referred to as 2400MHz)
and DDR4 dont clock as low as 1200MT/s, not that i know of, lowest i think is 1600/1866
-sigh- feeling like I'm being too negative lately
im let 80% sure i did. ill restart and check
task manager and cpuz (cpuz says 1199mhz but like close enough)
just checked, im in xmp profile 2. gonna update the post
can i get a screenshot of CPU-z?
because CPU-Z shows true frequency iirc, so it should be 1200
CPU-z it's fine it tells the actual data rate  instead of the Double date rate which DDR is, but the task manager tells the DDR speed (which is 2400 MHz in your case)  as far as I know....
CPU-z it's fine it tells the single data rate instead of the Double date rate which DDR is, but the task manager tells the DDR speed as far as I know....
task manager can be quite random, sometimes it shows true freq, sometimes it shows MT/s
here's mine (3666MHz)
Just now, Moonzy said:
task maanger can be quite random, sometimes it shows true freq, sometimes it shows MT/s
here's mine
Oh.. Didn't know that, thanks......
1 minute ago, Jetta said:
yea it's running at 2400, dont worry about it
CPU-Z shows true freq, which is half of the advertised MHz on the RAM and XMP profile
