3 exhaust fans, 2 intake? Is it okay?
Solved by Stahlmann,
Having more exhaust than intake will result in negative air pressure in your case and thus air will be pulled in through unfiltered areas. This way dust will build up quicker and you might need to clean it more often. But performance wise, it should be good regardless.
The "optimal" airflow setup in this case would be either 3x120mm or 2x140mm fans in the front as intake, 1x120mm at the top back as exhaust and 1x120mm at the back as exhaust.
