I got a notification for someone else's test post.
Solved by colonel_mortis,
That topic was originally posted in Hot Deals, then later moved to Test Posts. When a topic is moved, it doesn't remove existing notifications, but they do update with the topic's current state. I presume you're following Hot Deals, which is where the notification came from.
