Can I use a 2nd graphics card as a capture card
Solved by Moonzy,
Just now, RevplagueTv said:From what I understood from others is that it helps the pc that you are gaming on when you say outsource the encoding and all to a 2nd pc using a capture card
that is true but you have an 8 core CPU and your gpu has a decent encoder, so the impact should be minimal
Featured Topics
remo233 ·
Posted in New Builds and Planning1 -
ALBORLIN ·
Posted in Servers, NAS, and Home Lab0 -
1
i like xeons ·
Posted in Windows3 -
Chancla ·
Posted in Troubleshooting0 -
2
