VGA and... DVI.... >:C
Solved by Glenwing,
We use the term CCFL-backlit to distinguish older monitors that use fluorescent backlights as opposed to LED-backlit. (Well, I do anyway).
DVI and VGA have potentially the same visual quality, but as a non-digital signal VGA cannot correct any image degradation that occurs from electromagnetic interference, while DVI can. This is not always a problem for VGA of course, but it depends on the environment of use and how good the shielding on the VGA cable is. Sometimes it will look as good as DVI, sometimes it will be terrible. DVI also allows higher resolutions and refresh rates on larger monitors. In my experience DVI is also more reliable.
