Rx295x2 8 pin power melted
Solved by -rascal-,
5 minutes ago, Kd4lif3 said:Fr? It has a 500 watt tdp. I knew that going in and figured that 800 should work if it was dedicated to the card alone.
I don't recall the exact model but it is a Roswell 800 watt. Relatively new.
We would need to the exact model...
"Rosewill 800 watt" is like saying "Toyota 4-door car with an engine..."
From the looks of the damage, the problem started at the PSU end.
The PCI-E connector / wires are are not rated for such high current.
Too low of a current rating, and the wires runs HOT, melting the plastic.
The melting plastic on the PCI-E connector, then starts melting the PCI-E sockets on the GPU side, since they are connected.
