Mini ITX AM4 motherboad with front usb-c connector?
Solved by minibois,
1 minute ago, Duncwan said:At about 43:00 Linus mentions that the motherboard doesn't have the correct connector for the front usb-c port, I was wondering if there were any similar quality AM4 mini ITX boards with this connector?
I don't even know what the connector is called so I can't sift through spec sheets to check,
There aren't very many motherboard options with this connector.
PCPartPicker very helpfully has a filter for this connector, under "USB 3.2 Gen 2". Here are all the boards with this connector, for AM4 in mini-ITX size: https://pcpartpicker.com/products/motherboard/#xcx=0&s=33&f=8&O=1,2&sort=price&page=1
The manufacturer usually lists it as "USB 3.2 Gen 2" as well.
