Building HTML table the right way (need help)
Proxy408
Hi there, im trying to make this website for work. Im some what new to php/html/sql.
its like a kalendar, where i say i have this thing called "1102" og "1201" that starts from 07:00 AM, and goes on untill 10:30 AM, and ends at 11:00 AM.
They have to be under the right placement 15A-15B etc, from what is in the sql.
This was just a quick mockup with only HTML.
The issue im having is how to make the php/sql query output this the way i want.
maybe php/html combo isnt the right way, want to make a drag'n'drop so i can move "1102" to another time or placement as well. (Javascript is the way to do this?).
i am pretty good at reading completed code, but havent seen any examples of this to learn from.
Any tips is much appreaciated :)
Forgot to say, that maybe its my database structure thats not correct?
As of trying this i only have one table, with everything in it.
Here's an example of how you'd generate the table  with php code :
<?php
$column_titles = ['#','15A','15B','-','16A','16B','16C','16D','-','18A','18B'];
$column_titles_ids = [];
foreach ($column_titles as $id => $title) {
	$column_titles_ids[$title] = $id;
$records = [];
array_push($records, array('name'=>'1102','room'=>'15A','from'=>7*2,'until'=>12*2));
array_push($records, array('name'=>'1201','room'=>'16B','from'=>8*2,'until'=>13*2));
$grid = [];
for ($j=0;$j<count($column_titles);$j++) {
	$grid[$j]=[];
	$grid[$j][0] = [];
	$grid[$j][0]['text'] = $column_titles[$j];
	$grid[$j][0]['tag'] = 'c'.$j;
	$grid[$j][0]['color'] = '';
	for ($i=0;$i<37;$i++) {
		$grid[$j][$i+1] = [];
		$grid[$j][$i+1]['text'] = '';
		$grid[$j][$i+1]['color'] = '';
		$grid[$j][$i+1]['tag'] = 'c'.$j.'-'.$i;
		if ($j==0) {
			$half_hours = 12 + $i;
			$grid[$j][$i+1]['text'] = intdiv($half_hours,2).':'.(($half_hours % 2 == 1) ? '30' : '00');
			$grid[$j][$i+1]['color'] = 'white';
foreach ($records as $record) {
	$text = $record['name'];
	$column = $column_titles_ids[$record['room']];
	for ($nr = $record['from']; $nr < $record['until'];$nr++) {
		$grid[$column][$nr-11]['text'] = $text;
		$grid[$column][$nr-11]['color'] = 'ok';
		if (($nr >= $record['until']-3) && ($nr<$record['until']-1)) {
			$grid[$column][$nr-11]['color'] = 'warning';
		if ($nr==$record['until']-1) {
			$grid[$column][$nr-11]['color'] = 'danger';
<html>
<head>
	<style>
	  td span { display:inline-block; width:64px; height:32px;text-align:center; line-height:200%;}
	  .col-ok {background-color:green;}
	  .col-warning {background-color:pink;}
	  .col-danger {background-color:red;}
	</style>
</head>
<body>
<?php
echo '<table>';
for ($rows=0;$rows<37;$rows++) {
	echo '<tr>';
	for ($cols=0;$cols<count($grid);$cols++) {
		echo '<td><span data-id="'.$grid[$cols][$rows]['tag'].'" ';
		if ($grid[$cols][$rows]['color']!='') {
			echo 'class="col-'.$grid[$cols][$rows]['color'].'"';
		echo '>';
		echo $grid[$cols][$rows]['text'];
		echo '</span></td>';
	echo '</tr>';
echo '</table>';
</body>
</html>
Yeah, dragging those ... I would do it with Javascript ... there's drag and drop events you can hook into and all that.
holy moly. thank you so much @mariushm. This was way better then i expected to find 😄
