Am i supposed to have a hdd led cable on a corsair r275 airflow
G-spot
Hi, i have a corsair r275 aurflow, and on those little front panel cable tgere is no hdd led, is in neccesery or is it normal
depends, if you have a hdd,its reccommended. if you have no hdd, the lked is useless
                         Dream build:
Intel Core i5-10600K | GIGABYTE Z490 AORUS ELITE | Cooler Master MasterLiquid ML240L| RGB Corsair Vengeance RGB Pro  16GB (2x8) CL18 3600MHz |
Intel 660P 512GB NVMe | Kingston A400 SSDNow 480GB 2.5" | WD "Caviar" Blue 1TB 7200RPM 3.5" | MSI GeForce RTX 2060 Super Gaming EVGA SuperNOVA 750 G+ | THERMALTAKE RGB H200 USB 3.0 |
Peripherals:
Keyboard: Corsair K65 RGB Rapidfire
Mouse: Corsair Harpoon RGB Pro
Monitors:
(1) LG 27'" 27Gl650F-B 144hz 1ms IPS G-Sync Pivot 3
(2) Acer Predator XB241YUbmiprz 23.8" 144Hz 1ms G-Sync
Headset:
Kingston HyperX HX-HSCSC2-BK-WW Cloud Stinger Core
14 minutes ago, WikiForce said:
no, it's useful in many situations like when your computer feels slow and something in background is actively running on the a drive (doing constant read / writes)
it even shows SSD activity, literally any kind of storage device, HDD LED is just the name because at that time (when it was introduced) there were not SSDs
i didnt know that
                         Dream build:
Peripherals:
Monitors:
Headset:
It's useful for knowing if your PC has crashed or just loading up, for example by screen is just black, so I press random buttons on the keyboard and see if it causes any activity on the HDD
Please tag me @RTX 3090 so I can see your reply
Ok i would like to have it but is not included in my case, do i have to buy it now and like plug it in the case in someway
Many cases and prebuilts doesn't include one. I guess the industry is thinking it's not -sexy- enough and that including it may lose them sales because it's not RGB HDD LED....?
