5900x has terrible thermals, need help!
lugs
Specs of my PC:
PCPartPicker Part List
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor
CPU Cooler: Noctua NH-D15 CHROMAX.BLACK 82.52 CFM CPU Cooler  ($243.00 @ Amazon)
Motherboard: Asus ROG Strix X570-E Gaming ATX AM4 Motherboard  ($319.99 @ ASUS)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($169.99 @ Newegg)
Storage: Gigabyte AORUS NVMe Gen4 1 TB M.2-2280 NVME Solid State Drive  ($179.99 @ Amazon)
Storage: Samsung 870 QVO 1 TB 2.5" Solid State Drive  ($99.99 @ Amazon)
Video Card: MSI GeForce RTX 3080 10 GB GAMING X TRIO Video Card  ($1585.98 @ Amazon)
Case: be quiet! Pure Base 500DX ATX Mid Tower Case  ($99.90 @ Amazon)
Power Supply: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($172.04 @ Amazon)
Running everything at stock, the CPU runs idle at 75-80C, I've tried reapplying the paste and cooler to no avail.
I found that my mobo has an "auto tweaker" function, which lowered temps to 45-50C, but the clocks were limited to 3.9GHz. I'm guessing this rules out the issue of the cooler?
Both scenarios are pretty bad, so what settings/programs should I use to optimize this? Better thermals, but not sacrificing my clock speeds? As I am a total newbie when it comes to CPU configuration, any help would be appreciated!
EDIT:
I tried to experiment a bit through the use of auto-tweak in AI Suite 3, which brought idle down to 55-60C, and I boosted the multiplier to 44x (to 4.4GHz). Benchmark scores improved, but all the CPU cores ran at pretty much 4.4GHz all the time. Is this safe?
1 minute ago, lugs said:
Running everything at stock, the CPU runs at 75-80C, I've tried reapplying the paste and cooler to no avail.
under what load?
if it's all core 100% at cinebench or similar tasks, that's absolutely normal for stock settings
in fact, slightly lower than expected, as normally i would expect 80-83c, depending on ambient temp
-sigh- feeling like I'm being too negative lately
1 minute ago, Moonzy said:
under what load?
Sorry I worded that wrong. Those are idle temps just on desktop >.<
1) did u remove the plastic on the cooler's coldplate (if any)?
2) did you screw in the cooler until you feel a stop? if not then it's not having enough pressure
3) are the fans spinning?
Yes to all.  And I edited some info in the original post ^
Yes to all.
can i get a photo os ryzen master running?
interested to see clock speed, voltage, and temps
maybe include task manager too, i wanna see the cpu load graph
though... what's the load temp like? in cinebench.
Ryzen Master
Task Manager at idle
Cinebench temps (from 75C idle) is 83C, but the score is terrible, only at 7250-7350pts
All of this as far as I know is stock except for DOCP
Task Manager while running Cinebench multi core
try to make a negative voltage offset rom bies- lie -0.05V at first. that will reduce voltage at idle.
your cpu does not seem to be idle since it uses like 70W of power. that is pretty big usage for idle.
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
How do I do this? Sorry
bios.
Need help with setting voltage for i7-8700K
offset mode sign: -
offset voltage type -0.05
other leave as they are.
Main PC:
Test Rig.
Just Sold
Ask me anything :)
It's running over 1.4v idle, that's a lot.
Btw, is the heatsink warm/hot to the touch when the CPU is running at these temperatures?
If no, then it's still parly a contact issue.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
I had that board once and it had the feature. almost everyboard does.
Main PC:
Test Rig.
Just Sold
Ask me anything :)
If they are not in the manual, that doesn ot mean that they do not exist. they should be under the ai tweaker tab on advanced mode.
Main PC:
Test Rig.
Just Sold
Ask me anything :)
Looking at HWMonitor while just on chrome, it seems like theyre all running at 1.4v
2 minutes ago, boggy77 said:
are you on the latest bios version?
Latest BIOS that isn't beta, yes.
Did I do this right? Max voltage dropped from 1.45v to ~1.41 (temps are pretty much the same though)
3 minutes ago, boggy77 said:
go for the beta.
Are there any major problems that could come from using the beta?
YEAH seems about right. try 0.075V now. that is the highest i would go
Main PC:
Test Rig.
Just Sold
Ask me anything :)
This is what it looks like now. Are there any more BIOS settings I could use to help temps? The rest of the board is on stock bios version 3202
what power plan are you on? you should use balanced, not max performance, to allow the cpu to downclock when idle.
voltages seem fien now
Main PC:
Test Rig.
Just Sold
Ask me anything :)
your clocks are a bit high. like all corees 3+ghz. normally at idle 1-2 cores should be at 4.5ghz+ others at sleep
Main PC:
Test Rig.
Just Sold
Ask me anything :)
