High temps on 5600x
NLamki
So a couple weeks ago I got the 5600x. I only started using it last week because I was trying to find a resonably priced 3070. Anyway, I've noticed that the temps are crazy. 40-45 on idle -not an issue I think- But while gaming, it hits temps so high that it thermal throttles. I'm using the stock cooler with 5 case fans (2 front intakes, one top intake, one top exhaust and one back exhaust). Are my temperatures normal or should I upgrade to a better cooler?
and for the better cooler, would I be able to get away with the esports duo air cooler or would I need something fancy like an aio? (If I'm getting an aio then I'll save up and go for the NZXT z63)
Another question, my current power supply is 500W. Is that power supply enough or do I need to upgrade? I haven't noticed any issues but would I be losing some cpu performance if my power supply wasn't strong enough?
You say it's throttling, but don't say what the actual load temps are.
So.... What are the load temps?
As for your PSU, that mostly depends on the GPU you're currently using. So please tell us that as well. I'm assuming a 3070, but your phrasing is unclear to me.
Primary Gaming Rig:
Ryzen 5 5600 CPU, Gigabyte B450 I AORUS PRO WIFI mITX motherboard, PNY XLR8 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 500GB SSD (boot), Corsair Force 3 480GB SSD (games), XFX RX 5700 8GB GPU, Fractal Design Node 202 HTPC Case, Corsair SF 450 W 80+ Gold SFX PSU, Windows 11 Pro, Dell S2719DGF 27.0" 2560x1440 155 Hz Monitor, Corsair K68 RGB Wired Gaming Keyboard (MX Brown), Logitech G900 CHAOS SPECTRUM Wireless Mouse, Logitech G533 Headset
HTPC/Gaming Rig:
Ryzen 7 3700X CPU, ASRock B450M Pro4 mATX Motherboard, ADATA XPG GAMMIX D20 16GB (2x8GB) DDR4-3200 CL16 RAM, Mushkin PILOT 1TB SSD (boot), 2x Seagate BarraCuda 1 TB 3.5" HDD (data), Seagate BarraCuda 4 TB 3.5" HDD (DVR), PowerColor RX VEGA 56 8GB GPU, Fractal Design Node 804 mATX Case, Cooler Master MasterWatt 550 W 80+ Bronze Semi-modular ATX PSU, Silverstone SST-SOB02 Blu-Ray Writer, Windows 11 Pro, Logitech K400 Plus Keyboard, Corsair K63 Lapboard Combo (MX Red w/Blue LED), Logitech G603 Wireless Mouse, Kingston HyperX Cloud Stinger Headset, HAUPPAUGE WinTV-quadHD TV Tuner, Samsung 65RU9000 TV
usually 85-90 on games and about 100 when using cinebench.
Zotac twin edge OC 3070
8 minutes ago, DriftMan said:
Stock cooler is not enough for intensive usage, just get some high TDP air cooler and it will be fine
What do you recommend?
PSU should probably be 600 or higher, but might be ok. Trying won't hurt anything other than maybe crashing from poor power delivery.
It really shouldn't be that hot, even with a stock cooler. I'd check your Auto-OC settings and turn them back/off if they are enabled.
Regardless though, a Hyper 212 or any comparable tower cooler will be more than adequate.
Primary Gaming Rig:
HTPC/Gaming Rig:
I've been using it for about a week with heavy games like cyberpunk and microsft flight sim and no crashes so far.
Yep Auto-oc is enabled.
Alright, thank you.
I had a similar issue when i got my R5 3600, got a Pure Rock Slim and that lowered temps by around 10c...
-> Moved to Cooling
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Arctic Freezer 34, Id-cooling se-224-xt basic etc style of coolers are plenty enough for a 5600X.
And the amount of case fans does not really tell that much. A case with very limited airflow with 5 fans is worse than a decent case with 3 fans.
22 hours ago, DriftMan said:
Phanteks TC14PE, BeQuiet! Dark Rock Pro 4, Noctua NH15... Go to the air cooler section, there will be lots of posts with information about good cpu coolers, please check the posts before posting another one
Most of these are overkill.
Go with a U12s or a hyper 212. If you want the maximum cooling then go with the sythe fuma 2 which is like a cheap NHD15 equivalent.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
