Does a 4 pin CPU connector work with an 8 pin Motherboard?
3 minutes ago, Mateyyy said:You can plug just a 4-pin in the 8-pin EPS connector on the motherboard.
But, the fact that your PSU doesn't have an 8-pin EPS connector to start with, and that it can only output 15A on the 12V rail (so 180W), is a little alarming, to say the least.
Basically, I'd recommend you buy a non-dumpster-fire power supply, instead of potentially creating more problems.
You don't need to break the bank to get something decent - there's units like the Corsair CX/CXM, Cooler Master MWE Bronze v2/White v2, be quiet! System Power 9/Pure Power 10 or 11 400W+ (not the 300/350W variants) or Seasonic S12III, which should power your components just fine at an acceptable price.
okay, thank you very much. this was very helpful.
