Looking for an "inverse" chassis. ideas?
Solved by W-L,
2 hours ago, guljfesk said:So, for practical reasons i would like an inverse chassis. mobo on left side (when looking from the front side)
Ive seen some chassis around on the net, but most of them are out of production.
Anyone got some good tips or maby a name to search the web for "modular/inverse chassis" ?
Be quiet is pretty good if you want an invertible layout case that is designed for silence. I believe it is their dark base lineup that has that feature.
