while true and if statements
Enderg312
I am trying to loop my program with a while true but I have an if statement in there and if I type close it is suppose to close it and with the while true it wants to ignore the close part. How to I allow my program to loop and close when I type close?
And it is python coding.
You can use break to stop executing a loop, like e.g.:
while True:
	if(someconditionhere):
		break
while True:
		break
Can you explain more because all that is doing is stopping the while True altogether?
Eternal loops can only be stopped if you apply a inner if/else statement. so like @WereCatfexplained:
inpt = input("What do you want? ")
while True:
    if inpt == "close":
        print("looped stop")
        break # You can also use sys.exit() to terminate the whole program
    else:
    	# If the input insnt close you dont want to lock the loop
The else part is not "mandatory" but if you want to have always a way to trigger that if
Current Rig:
Mobo - MSI B450 Pro-Max VDH | CPU - Ryzen 5 3600 (AMD duh) | GPU - GTX 1660 Super (MSI) | WAM - 2 x 8GB 3200MHz (G.SKILLS Ripjaws)Storage - 1 x 256GB SSD (Crucial MX500) + 1 x 2TB | HDD 7200RPM (Seagate Barracuda) | PSU - Cooler Master 450W | Case - Cooler Master Q300L | Display - Asus VP248QG (Main) + AOC 24B1W1 | Other Stuff - Bloody B120 (Keyboard) + HP X220 Gaming Mouse + Asus A541UJ (Laptop)
2 hours ago, Emily123 said:
Why not just make a Boolean for your while loop and then set it to false when you want it to stop?
This is also my preferred method. In a simple program like this, it usually goes something like:
stopMe = False
while not stopMe:
  myVar = GetUserInput()
  if myVar == "stop":
    stopMe = True
  else if myVar == "go":
    MyGoFunc()
  else if myVar == "andOnandOn":
    MyOtherFuncs()
EndOfLoopFuncs()
The standard user input loop is:
  1. Get input
  2. Parse Input
  3. Operate on Input
  4. Goto Step #1
ENCRYPTION IS NOT A CRIME
