10700f VCCSA VCCIO voltage questions
Solved by DoctorNick,
13 minutes ago, Algebruh said:Can you change VCCSA and VCCIO voltage on 10700f?
The motherboard is ASUS Z490-E
Yes. But you can't change the multipliers, that's the difference between K and non K models. In your case the F model also has no iGPU.
Featured Topics
Shay04 ·
Posted in CPUs, Motherboards, and Memory1 -
1
hconverse02 ·
Posted in Audio11 -
Rogue57Chevy ·
Posted in Graphics Cards11 -
Ricodotsh ·
Posted in Power Supplies3 -
6
bloodknightoo ·
GreenGDK ·
Posted in Troubleshooting1 -
RLT_Byers ·
Posted in Peripherals1
play_circle_filled
Latest From Linus Tech Tips:
I Will NOT Give You $250 for Your Broken Game - WAN Show April 26, 2024
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
