Cyperpunk 2077 HORRIBLE low FPS with low GPU usage
Solved by Darkshadlok,
2 minutes ago, Fasauceome said:is your ram running at rated speed?
recommended spec is an i7-4790, a 2700X should be more than enough.
Yeah same opinion, in the videos u can see how low the CPU usage is... If the CPU would be the prob it would run on 100%
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting2 -
2
1
6
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
Shane Martin ·
Posted in Displays2
