at 1080p? If you turn on RT effects, use 3080. Or 3070, cuz AMD is just not competitive here. If you wont be going beyond 1440p 16:9 anytime soon, then 6800XT itself is still the better choice but it's a minor difference. Also custom models should still be the focus, this time the reference cooler doesnt suck but at the same time, is not impressive. Increasing the power draw by raising the power limit causes temperature and noise level to significantly soar for example.
Desktop benching:
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14223735
13 minutes ago, TheLesso said:
Whould you recomend a radeon 6800xt or rtx 3800?
My uses will be gaming at 1080 and i will also have a 5600x.
amd drivers?
"Haha new amd drivers go brrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr"
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14223755
Whic ever is cheaper. 6800XT is slightly slower, but has better cooler  than the Nvidia's (lower dba)
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14223784
6800 xt for everything except ray tracing. Also for longevity due to more vram
CPU: Ryzen 5500 GPU: RX 6800 RAM: DDR4 3200MHZ 48GB (2x8+2x16 GB)  MOBO: MSI B450-A PRO Display: 4k120hz with freesync premium.
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14223787
Neither, because you'll never be able to get one retail till probably some shit like April.
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14223914
Seems about right. This is price inflation in the form of a shortage imo.
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14223960
Yeah I said screw it and picked up a 5700XT. Not like RT or DLSS is in any other games outside of Control and Metro.
I feel like Ray Tracing and DLSS are in a similar state as Pixel Shaders were when the GeForce 3 Ti came out. Yeah it had pixel shading, but it sucked at it.
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14224754
I got downvoted to hell in r/nvidia for saying that before the 3080 was launched, I am frustrated I was right, but i find it funny this is the new norm
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14224769
The 6800XT should be better performing in everything but absurd levels of unoptimized raytracing with the 5600X and a 500 series motherboard. The 6800XT outperforms the RTX 3000 series in Dirt 5 with raytracing because Dirt 5 is using properly optimized raytracing.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14224961
At 1080p, I'm not sure either is worth it. You could probably move down to the 3060 tier and be fine.
Also what refresh rate are you targeting? I'm at 1440p 165Hz and was considering a 3070. Maybe a 3080 in case I want to be able to upgrade to 1440p ultrawide.
As far as AMD vs. Nvidia, I'm still leaning towards Nvidia for the drivers and feature set, but I don't think the new AMD would be bad either.
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14224966
Depends if you plan to record / stream, otherwise seems a wash. 🤷🏼
Though tbf, I'd really like to see a comparison with shadow play instead of OBS (also I don't recall relive being that bad, it just had issues with framerates, image quality seemed on par, using a 5500 xt)
-Scott Manley, 2021
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14224970
Comparison.thumb.PNG.fa57cfe922c723865a1c70e109343e81.png.bdaa180b012fb8f5efdf24c6aa1188a0.png
I mean the game looks like shit on everything, but the framerates don't look good for AMD, even with RT off, apparently.
And again, idk if that's a good comparison, seems highly biased for Nvidia, I mean the AMD doesn't even get a settings overlay... 🤔
As always don't believe yt videos, check for yourself then you can't get (overly) disappointed...
-Scott Manley, 2021
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14224992
13 hours ago, knockless said:
amd drivers?
Given how the 6800 XT is competing with the RTX 3080 with initial release drivers...AMD did a pretty good job.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14225039
I dont feel the calculation is that different than the 5700XT vs 2070Super argument.
Seems like at least so far AMD drivers arent an issue, which is great, but I have been burned too many times not to keep a stank eye on them until I am absolutely sure
Really the same argument though with slight modification.  Price a little more on 3080.  Little more frames on 3080.  Ray tracing better on 3080 (RT has a narrower gap now, as there was nothing before from AMD).  But AMD does have RT at a little lower price.
Funny thing is at this point everyone will probably buy whatever they can get their hands on with this crazy demand.  I would go Nvidia myself, but only because I was burned by AMD too many times to fully trust them (though I am sure other have Nvidia stories of the same sort).
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14225166
So so many...
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14225249
That is what i thought about. 6800XT= 5700XT and 3080=2070S. 5700XT is a better buy for users who do not use RT and record. 2070s to who record a lot and use RT.
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14225517
Ray Tracing and DLSS are still very raw in performance and game library. Ok, maybe not DLSS, but thats a software implementation over hardware requirements. But I would not hold my hopes for a decent library with RT support any time soon. I would be exited, if devs would roll out RT patches or DLCs (like with 4K DLCs when 4K became a stable thing). 2 generations from now, I would predict RT to be mature enough to be a sell point. And at that point, its the 5 year upgrade time again...
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14225992
For 1080p I would wait for the lower tier AMD/Nvidia cards 3060/3060Ti if you want to dabble in RTX or AMD 6600 if it ever appears.
With sotcks the way they are, you are going to have to wait anyway or pay two to three times MSRP, at which point the €/fps goes out the window
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14226135
I agree with this. Additionally, Nvidia has a bit more perf and more features for $50 more so basically it's your own choice depending on what you want and whether those $50 make a difference for you.
At 1080p I'd get a 3070 though, since it's cheaper and will perform really well
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
https://linustechtips.com/topic/1270680-radeon-6800xt/#findComment-14226444
