driver_power_state_failure BOD but...
Solved by zignblowfly,
5 hours ago, Radium_Angel said:Ok, it's the usb driver stack, that went stupid because the Focus Rite device wouldn't let go of the IRP power state for other devices
Basically, that Focus Rite thing probably needs to be plugged into a powered USB hub, it seems to be drawing more power than it should.
Ok that makes sense. Ever since I unplugged the device I have had no blue screens...YAY! I'll try to plug into a powered slot. Hey thanks for the help! I REALLY do appreciate it. I feel like I have a good understanding of computers but I am no wizard and am still learning every day. Thanks again for your help and if there is ever anything I can help you with PLEASE let me know! Z
