CPU very hot after reapplying thermal paste and I have no idea why
Solved by Stahlmann,
1 minute ago, Shabba said:In my experience it's not how tight the mounting pressure is rather how even it is at each corner or side.
Just do your best to get the pressure even.
Don't over tighten, you don't want to break anything.
There has to be a certain pressure to make proper contact. Most cooler's screws are made specifically to bottom out when you have enough pressure.
