1 corner dark but working
nextg3n
Hello, recently recieved a montor where panel works but is dark at 1 corner, meaning no light behind it, is it possible to fix it. in thery it should since when plugged in or turned on it works for aroun 20seconds- 1 min and then 1 corner loses its panel light but it works the same, so my guess is that some connections are loose or there is a short somewhere in between? anybody have any good idea and knowladge how to fix?
Some EU input to Canadian IT :D
Probably a failing LED, but there's no way to know whether it's possible to fix and if so how without taking the thing apart.
F@H
GPD Win 2
well it is out of warranty and dont have anything to lose, so why not give it a shot.
Yes it is possoble to fix, but you dont need to fix it, if its new you should have a warrenty. So talk with who ever your warrenty is from, theyll tell you to send it to then, and then experts will fix it, and you wont have to pay for it. And if its not possible to fix they will have to send you a new one, even limmeted warrenties cover stuff like this.
well lenovo site says its out of warranty, ended 2019 sometime.
Did you buy it used? because if ytes then look at the site you ordered from buyers protection, its for stuff like that
brand new, company property and out of warranty.
Then talk with who ever you baught it from, maybe they wiil give you the money back and if not just buy a new one, give me budget and size you want and I can recomend you something
