PLEASE HELP ME FOR MY FIRST PC BUILD!
YMD_CHOCCY_TECH_
Go to solution Solved by Yo soy Jack,
Just now, HelpfulTechWizard said:
lol, you would not have a good system with a 3070. The monitor would be about $200, so you have $1000 for the system, which doesnt really work. I would wait for ryzen 5000 in a week or so, and would get a used  2070 or 2080. BitWit "did" a 1000 3070 build, but it didnt end up well, he had a d3sh and a 80+ smart in a $1000 build, and both are known for being low quality.
Yeah you’ll need a higher budget to make it with a 3070
HELLO EVERYBODY!
i am a big tech enthusiast and I really have been inspired by Linus's pc builds for 2 years but the BIG PROBLEM IS THAT im a 13 year old boi and did hella RESEARCH and i also gathered a lot of knowledge this past months seeing all platforms and linus's vids. i did come up with a configuration but im still doubtful as its my first pc and i dont wanna mess things up.lol
my budget is starting from 1000$ to max/1200$.including the monitor. I feel like its a nice budget era to start of.
my default points would be;
the GPU will be GeForce RTX 3070.(I'm really obsessed with that XD)
and a gaming monitor with a decent at least 144hz refresh rate.
it will be an ATX build.
it could be intel or AMD(which ever gives me the best performance at this budget)
sooo,please give me a really good configuration!
THANKS!
from your 13 year old boiii
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
It’ll take me some time but I’ll try to make a list for you but it might be difficult to make one under 1.2k
PCPartPicker Part List: https://pcpartpicker.com/list/qJB4Xv
CPU: Intel Core i7-9700K 3.6 GHz 8-Core Processor  ($269.00 @ Amazon)
CPU Cooler: MSI MAG CORE LIQUID 240R 78.73 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard  ($394.98 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3000 CL15 Memory  ($174.99 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI GeForce RTX 2080 SUPER 8 GB GAMING X TRIO Video Card  ($869.99 @ Staples)
Case: Thermaltake V200 RGB ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: Asus 850 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($229.64)
Total: $2338.54
Generated by PCPartPicker 2020-12-08 10:04 EST-0500
you can change what you like but heres the basics
PCPartPicker Part List: https://pcpartpicker.com/list/FH6xZf
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($294.99 @ Walmart)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($188.35 @ Amazon)
Memory: Team T-FORCE VULCAN Z 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($94.99 @ Newegg)
Storage: Kingston A400 120 GB 2.5" Solid State Drive  ($24.99 @ Amazon)
Video Card: RTX 2070 EVGA KO version (309.00)
Case: NZXT H510 ATX Mid Tower Case  ($69.98 @ Amazon)
Power Supply: Corsair RM (2019) 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($143.00 @ Amazon)
Total: $1180.99
Generated by PCPartPicker 2020-09-30 12:17 EDT-0400
You're not going to be able to make a system that has to have a 150-200 dollar monitor WITH a 3070 a REALY expensive  card especially for this price point.
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
Total: $2338.54
1 minute ago, SignatureSigner said:
-snip-
lol, the GPU doesnt have a price, and you forgot a minitor.
Bios database
prior build:
I know (I dont think you can make a pc with a 3070 and have a budget of under 1500) I just wiped that together as a base.
System Specs
Peripherals
<Razer Mini>
bit wit "did", but it was a pos. d3sh and 80+ smart in a 1000 build smh
Bios database
prior build:
I wouldn't use that in a system with components of that size with those parts :/ I agree with ya :)
System Specs
Peripherals
<Razer Mini>
You would not be able to get a good build with a 3070 for 1000$, I would go with something like this instead
You can swap rx 5700 xt for a rtx 2070 super if you find a good deal for one
It is slightly over budget, but you can always look for refurbished/used parts.
YOU ALL HAVE MY THANKS FROM THE HEART!
for sparing your time for my problem and making this lists of configurations also, sharing your opinions!
mmm...i do have an idea to slide in the rtx 3070. if i exclude the monitor's expenditure, may I put a 3070 in my system and if not how much more will i have to spend?
oh and also what do you think of @boggy77's configuration listing? im looking forward to his one too.I think i will be able to spend that much difference in budget
