What is bottleneck? How much effect does it have?
Solved by boggy77,
People wrongly think that by getting a stronger gpu and thus creating a "bottleneck", the performance will be lower, which is wrong. By adding a faster component, the performance will always be better.
Let's take your example. Say you have 100 fps now in a certain game. You get a 3080, your fps becomes 130. But now your cpu is the weakest link, "the bottleneck". That doesn't mean the performance isn't better, it just mean that if you now replaced your cpu, you'll get 140 fps.
