Is there any way to use Desktop PC without Monitor or TV but I don't have a internet? So I need to use PC without buying an LCD Monitor or even without TV.
My Desktop PC has VGA Port and DVI Port. But I cannot access to remote desktop even with internet connection.
https://linustechtips.com/topic/1244786-using-an-pc-without-monitors-and-internet/
Yes you can use remote desktop.
You need to activate remote desktop and open the firewall.
Connect the server with the local IP Adress.
You don't need internet you need network, unless you can control it with your brain wave.
The earliest computers just had a keyboard and a printer. Of course I'm not sure how well modern OSs support such a "user inteface" 😁
But seriously, a computer without a monitor only makes sense if you can connect to it remotely (either local network or internet). In most cases such a setup would be a server of some kind (web server, terminal server, ...)
You know, used monitors are really cheap pretty much everywhere in the world. You might even be able to get one for free, they get thrown away all the time. You can also hook it up to a TV.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
You could use it with screen reader. But honestly, what were you planning to use as interface or how you planned to use it?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
But I think you need a monitor first to activate remote access
and how do you plan to remote access the computer
Hi
hi
3 hours ago, fpo said:
SSH
TTS
he still needs a local network for those tough right?
