How much psu do I need?
Bayron
My system:
Cpu ryzen 5 1600 af (stock)
MB Asrock b450m hdv r. 4.0
Ram dd4 2666mhz 16 GB g. Skill value
Gpu inoo3d gtx 1650 super twin x2 oc
Ssd/hdd 1 240 kingston ssd, x2 7200 rpm hdds
5 Aigo DR12 rgb fans whit controller
AMD wraith max cooler for cpu
Rgb keyboard, mouse
Most of psu calculators show somewhere 300-300w psu, so would 400w psu would be enough?
Currently have fsp 700 w psu but it's a bit old and I'm scared i5 can Die and take my pc whit it
Maybe I will overclock in future, but not sure about that cuz I have never done that and I have enough power for my usage.
Tnx for help :)
  • CPU
    Ryzen 5 1600 af 3.2 ghz
    Cooler AMD Wraith Prism rgb
  • Motherboard
    Asrock b450m-hdv r4.0
  • RAM
    16gb g.Skill 2666MHz
  • GPU
    Inoo3d 1650 super twin x2 oc
  • Case
    Genesis titan 750
  • Storage
    Kingston a400 240gb(system)
    Seagate barracuda 2tb 7200rpm(storage)
    Samsung 1tb 7200rpm(backup)
  • PSU
    Fsp si series 700w 50arn 88% efficiency
  • Display(s)
    Dell ultra sharp 24" 1080p
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
    Trust rgb gaming mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
at worse this system wont consume more than 200-230ish watts, psu calculators are wrong most if not all the time.
budget for a psu?
Phone: Pixel 3a (Purple-ish).
Build Log:
The cpu probably need 50-80w.
GPU around 150 top when gaming.
Browsing the web, office etc you'll probably use only 100w total.
budget for a psu?
50-60 euros, looking at system power 9 400w or corsair cx 450 cuz they have cables what I need and are good for bottom mounting, which is what I need
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
10 hours ago, Bayron said:
50-60 euros
yea the cx450 and the system power 9 400w are more than enough, if you couldn't fine one, an MWE bonze V2 450w is also good.
though for a little more than 60 euros, you can probably find something like a tx550m or a bit fenix formula gold or a seasonic focus gm which are good.
Edited by TofuHaroto
Build Log:
OK Tnx I'll check out all options
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
    Genesis titan 750
  • Storage
  • PSU
  • Display(s)
  • Cooling
    X4 Led case fans
  • Keyboard
    Redragon k552-rgb
  • Mouse
  • Sound
    Steelseries artic 1
  • Operating System
    Windows 10 home
