Fingerprint on HP Probook 445 G7 Not working.
Solved by ToolMan,
HI, I found a thread on the exact issue you have. Apparently, your laptop has the little indent on the palm rest for the fingerprint scanner, but maybe not the hardware that's supposed to be underneath. I found that for your laptop, the scanner is an optional feature, but if you are sure its an option yours has, it may be a hardware issue.
You can always try going into device manager and scanning for hardware changes.
Featured Topics
kazimalizaidi ·
Posted in Cooling1 -
d3mueller ·
Posted in Troubleshooting0 -
JangerBanger ·
Posted in PC Gaming1 -
4
kuzzikan ·
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
