Advice on CPU upgrade
Go to solution Solved by zeusthemoose,
2 hours ago, Silencix said:
this i chose to upgrade my current i7-7700 is it ok to buy this or should i change something?
That will definitely work. However, you should consider waiting until later this year when ryzen 4000 drops though because that will be more worth your money.
Hi, I have a 7700 and want to upgrade, I use the pc to play. My budget is 20,000 Argentinean pesos for the cpu and the motherboard. I hope that with your experience you can help me to choose the best cpu and motherboard to upgrade my pc. The online store where I can buy is https://www.mercadolibre.com.ar/.
Thank you very much.
Best regards.
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/
What are you missing out on your PC currently (as in, what games don't play well or whatever)? What videocard do you have currently?
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13905903
wait for zen 3 (Q3/Q4 of this year supposedly) and check what it has to offer.
Edited by TofuHaroto
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13905909
3 minutes ago, Silencix said:
because the 7700 I think is obsolete, video card I have an rtx 2070.
Are you happy with your performance? If so, doesn’t matter if there is newer stuff, don’t upgrade.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13905928
1 minute ago, Skipple said:
What are you not getting from the 7700 that makes you want to upgrade?
because I think there must be some processor that has more efficiency and performance than mine, but I don't know if it's within my budget so I ask here in the forum.
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13905939
Why does the Council in the title mean.
Does it have anything to do with you saying this to your CPU:
Lighting Light Candle Darkness
(The Council will decide your fate)
please quote me or tag me @wall03 so i can see your response
motherboard buying guide      psu buying guide      pc building guide     privacy guide
ltt meme thread
folding at home stats
pc:
RAM: 16GB DDR4-3200 CL-16
CPU: AMD Ryzen 5 3600 @ 3.6GHz
SSD: 256GB SP
GPU: Radeon RX 570 8GB OC
OS: Windows 10
Status: Main PC
Cinebench R23 score: 9097 (multi) 1236 (single)
don't some things look better when they are lowercase?
-wall03
hello dark mode users
goodbye light mode users
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13905940
There will always be better hardware then what you have.
But unless there is something about your current hardware that requires you to upgrade, anything you do will be superfluous.
ask me about my homelab
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13905945
It doesn’t not look like there is a cpu in your budget that would give you a good increase in performance or efficiency.
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13905946
18 minutes ago, Silencix said:
I ask because there are so many advances that a Ryzen 3 3100 has the same amount of cores as my 7700. Maybe even better than my 7700.
Same amount of cores, and threads, but a little less performance. You should keep the 7700 for now, new products should arrive soon, we will see how prices change.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13906054
Nope.
Not a good upgrade. More of a side grad.
Wait for zen 3. Because unless you absolutely need an upgrade now, the 7700 will do the job.
Build Log:
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13906058
Like others have said, not an upgrade. At best it will be equal but most of the time the 7700 will be very slightly ahead. But it doesn’t seem your budget could fit a 3100 and a motherboard anyways.
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13906069
  • 2 weeks later...
In your experience which is better, the 10400, 10600K, 10700, 10700k or the 3600 or 3700x? On the net there are thousands of comparisons that confuse me. In real performance, whether for gaming and editing, which one is better?
within that price range I can buy a processor to upgrade. I've increased the budget a little bit.
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13941438
I don’t have any personal experience with these CPUs, but from the reviews and benchmarks I’ve seen. In gaming the 10400 and 3600 trade blows and which one is faster depends on the game, the 3700x is slightly faster than those, the 10600k is a bit faster, then the 10700 which once again is slightly faster, and lastly the 10700k. But with light overclocking, the 10600k can easily match or outperform the stock 10700k. I wouldn’t recommend buying a locked (non-k) Intel cpu.
In performance tasks which use more cores and threads, it goes 10400, 10600k, either 3600, 10700, or 10700k (idk 100% which performs better here but I’m guessing it’s the 3600), and lastly the 3700x.
Maybe this will help you a bit more as well: https://www.gamersnexus.net/guides/3589-best-cpus-of-2020-so-far-gaming-production-overclocking-budget
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13941809
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13942452
PSU Tier List
SSD Tier List
PARROT GANG
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13942855
Thank you very much. I already made the purchase. :)
https://linustechtips.com/topic/1232420-advice-on-cpu-upgrade/#findComment-13942866
