Cases with no PSU fan hole cause PSU to overheat?
Solved by Ralf,
3 hours ago, Pc6777 said:So I had a few random restarts only at heavy load a few months back in a PC,it was sucking in air that was like 30 to 45 c at load. How important is it for a PSU to have isolated airflow from rest of the case and so you think my hypophosis is right?
3 hours ago, Pc6777 said:Well that explains it, it was sucking in super hot air in a case with extremely bad airflow at load
My G3 550W(top mount) and a 80mm hole is the only exhaust in my old PC, so the psu draws hot air(50-60℃) from FX8320 with HR-02 Macho(which is literately blocking the psu from getting any fresh air) and it is still working fine, no restarts whatsoever.
